Hey everyone, I’m a beginner and I’m looking forward for help to designing my DIY grid-tied solar system for two different options/scenarios which I would like to compare and choose. I’m looking for an Energy Storage System (ESS), it is a specific type of power system that integrates a power grid connection with a Victron Inverter/Charger, GX device, and battery system. Below the diagram of the ESS, are the two different scenarios. The location is SEVILLA, SPAIN.
When the grid is down, we would like to power our essential loads from the batts and at least 12kWh of continuous max power for essential loads.
30kWh battery storage.
When the grid is up, we will have at least 27.6kVA of continuous max power available for all the loads from the grid. The expected continuous power consumption (24h day), when the grid is up is to be around 10kW * 24h.
For this, I would like to have two different PV systems, one to charge the batteries (PV on DC) with the right size and power, and another PV system (PV on AC output) to offset our power usage from the grid and/or the batteries.
When the grid is down, we would like to power our essential loads from the batts and at least 15kWh of continuous max power for essential loads.
60kWh battery storage.
When the grid is up, we will have at least 27.6kVA of continuous max power available for all the loads from the grid. The expected continuous power consumption (24h day), when the grid is up is to be around 16kW * 24h.
What I would like to know is what equipment will be needed for each setup above described. I would like to determine the right size for the PV system on DC to power our batteries during the day. And I would like to determine the right size for the PV system on AC to offset our power usage from the grid and/or the batteries. Imagine there are no constraints on the size of these PV systems, the only thing I’m looking for is the optimal setup to maximize my investment.
The equipment vendors that we can use are:
Finally, I would like to know if it would be worth it to have power optimizers per PV panel given the fact that shade won’t be a problem.
Thank you so much for all your help.
Scenario 1
ESS functionalityWhen the grid is down, we would like to power our essential loads from the batts and at least 12kWh of continuous max power for essential loads.
Scenario 2
ESS functionalityWhen the grid is down, we would like to power our essential loads from the batts and at least 15kWh of continuous max power for essential loads.
Design/planning help request
- VICTRON ENERGY
- BYD LITHIUM BATTERIES
- FRONIUS
- No restrictions on PV panels.
