buckeyestargazer
I'm adding a JK BMS to a 4S 230AH LiFePO4 battery and I'm wondering about the included on/off switch. This is the first BMS I have that came with a separate switch. The Daly I was using before was just "on" when connected to the battery. But it appears that the JK switch needs to be "on" in order for current to flow.
The switch is convenient I guess, but this battery will be in an RV in a location where it is not the easiest to access, so I'd rather not have to turn this switch on in order for the BMS and battery to work. What am I missing?
