Help with parallel
Siamac
Hood
MPPT: max 15A 600V
Panels: used panels (let's say degraded to 200W)
  • Open circuit voltage (VOC): 48.7 V
  • Max power voltage (VMP): 41.0 V
  • Short circuit current (ISC): 5.99 A
  • Max power current: 5.61 A
Let's say I have 8 panels in series right now. I want to add more arrays in parallel.
Can I add 1 array of 4 (slightly different orientation)
And 1 array of 12 (different orientation)?
And where do I connect the fuse for each array? Positive or negative?
If you're going in parallel, then each string needs to be the same (or similar enough) panels, so a 8s string can be put in parallel with another 8s string, but if you put it with a 4s string your array will act like two 4s strings and you'll lose 1/3 of your power potential.
