Update !
Recovered a bunch of cells, assembled 2 12v packs in 4s config and charged. First pack load test aborted early (approx half way) because one cell was dropping faster than the others, not a bad cell but poorly matched to the others. Pack #2 balanced very well and load tested at 169.08 AH, so safe to say they are 170ah cells. Pack # 2 cells only varied between 6 and 12mv until the very end of the test when the spread became worse with 10ah or so left to go. The inverter tripped out on low voltage (10.5) and the bms low voltage never triggered. Pack was at very close to 11V at end of test and dropping quick.
I have another 4S BMS on the way so I can test/charge 2 packs at a time to speed things up, I have 180 cells on hand and more coming so test time is important. I have two power supplies for testing, one 12V 25A that is variable 10-15V, and a bigger one that is 0-20V at 45A. Working with two setups at once will speed up things a lot.
Now, after the first successful test I have a good handle on what to expect and the characteristics of the cells. Discharge/capacity tests were done at around 50A because the BMS is only rated for 60A.
