Few things,
The gearbox from the old volvo is already gone, just have a keyed end of a prob shaft hanging there. The kit I bought came with a coupler and thrust bearing as part of the new belt drive.
Applicable piece:
Belt Drive Now Standard High torque drive belts and pulleys are now included in our reduction kits These are strong quiet solutions for sailboat conversions If steel chain is preferred please contact us for pricing and availability What is a gear reduction? Mounting assembly for the sailboat
www.thunderstruck-ev.com
I have spoken with them and can order belt wheels/belts to my hearts content to play around with the gearing.
When I looked at the chart after the last post it looked like around 3.5:1 might be the most efficient. It'd net around the same torque at cruise speed, and a good bit less draw (360ish vs maybe 560 1:1)
A key note to this project is that the motor is an auxiliary propulsion system, the sails are for long hauls. The motor is for going in/out of marinas, powersetting the anchor, and emergency/close quarter manuvers.. I can plan a weather window pretty good for island hops, and the runabout dingy I'll have hung on the stern davits has a 20hp outboard should all else fail.
Charging systems include 3x rec alpha 400 panels (boat will be in tropics, mounting location is great) 2x 400w wind turbines, and a 50w pedal generator from kpow for backup.
Battery bank was going to be 16s calb 100ah but I might spring for 300ah cells now. I've read that the larger the cell capacity the more susceptible it is to vibration/shock/impact damages in a mobile application. A bms that could handle 1000a 16s 2 or 3p would be ideal as then I could run more durable cells, but barring that I'd be willing to run the 300ah ones inside a multi layer vibration/impact isolating box (integral rubber mounting or some such finagelry).
I think another key note here is, as you said, the graph represents maximum draw not constant draw. As the boat gets moving its 18000 lbs sliding through the water will act as a big inertial modifier to the numbers we're crunching. Another note is the general rule of thumb that every knot of speed doubles (or halves when reducing) the fuel or power consumption. I may keep the 1:1, I may change it, I'll probably end up with 3 or 4 sets of wheels/belts lol - but I will almost never be running flank speed inside a marina xD
