Sverige
A Brit in Sweden
I’m using a 5000W Mensela IT-1 inverter which is running various low power loads around my house quite successfully, but for reasons I don’t understand, it just won’t light my LED security floodlights which are activated via a PIR detector and look like the photo below. They are just 8.5W each and I have three on a circuit, and when triggered by walking in front of them in darkness I see the LEDs faintly pulsing with a frequency of around 1Hz or so.
So what could it be about my inverter’s output which the LED lamps don‘t like, and could it be corrected somehow? I will get out there later today and measure the voltage reaching the lamps, but other outdoor lighting (led light bulbs) on the same circuit light up fine, so I doubt it’s anything as simple as a lack of volts.
EDIT: problem is now solved! It was my own silly fault for making assumptions about cable core colours designating function. I had connected my supply from inverter to the wrong “live” which was not actually making it all the way to the lamps! Doh…
