EMF from Smart Meters? High Energy Consumption?
Danke
Solar Wizard
36N 93W
I have no opinion (knowledge) on this, but curious what the electrical engineer types here think about these claims. Hype?
Bet viewed at link.
https://www.activistpost.com/2023/04/exper...s-included.html
Expert Reveals Utility “Smart” Meters “are programmed to overcharge consumers” (charts included)
TOPICS:BN FrankConsumer RightsSmart Meters
APRIL 24, 2023
By B.N. Frank
Opposition to privacy invasive and unsafe utility “smart” meters – electric, gas, and water – has been increasing in the U.S. and worldwide for over a decade due to ongoing issues associated with them including
billing errors and higher bills (see 1, 2),
cybersecurity risks (hacking and disconnection)
fires and explosions (see 1, 2, 3, 4, 5)
installation mishaps (see 1, 2)
harmful radiation emissions (see 1, 2, 3)
mechanical problems
privacy concerns and
short lifespans
“Smart” meters are so controversial they inspired a documentary film! Nevertheless, utilities as well as other proponents continue to promote them as being beneficial to consumers, essential for “energy efficiency”, and safe despite articles, reports, research, and testimonials proving otherwise (see 1, 2, 3, 4).
From Westview News:
Electrical Engineer Explains How “Smart” Meters Can Lead to Higher Bills
Jill McManus Interview with Bill Bathgate
My grandchildren Teddy and Sofia complained about the jump in their electric bill. And Dusty provided them with the following article. – George
To get more information about the inner workings of “smart” meters, we spoke with professional electric and mechanical engineer William S. Bathgate. [Bathgate worked at Emerson Electric as Senior Program Manager for Power Distribution Systems in charge of RF and IP based digitally-controlled high power AC power switching system products that sold worldwide. He has also served in the U.S. Missile Defense Agency, NASA, and Homeland Security. He is certified as a Building Biologist and Electromagnetic Radiation Specialist by the Building Biologist Institute, and an IEEE Certified Radio Frequency Safety Officer. He has testified on behalf of Resident Customer groups in Michigan and Iowa that have worked to prevent rate increases and installation of low-quality meters. He has two companies, has conducted many tests in his own lab and has test results from over a thousand homes. https:// buildingbiologyinstitute.org/find-anexpert/ certified-consultants/buildingbiology- environmental-consultants/ william-bill-bathgate-bbec-ieee/] While some details may appear very technical, the central theme here is that smart meters emit excessive levels of EMF radiation, harm the environment by consuming energy unlike analog meters, are programmed to overcharge consumers, and are vulnerable to cyberattack. Now here’s the breakdown. Bathgate’s information was eye-opening.
To illuminate the laxity of the FCC guidelines, Bathgate offers this example: intensity of electromagnetic radio frequency (EMF) in sleeping areas is 10- 100 microwatts per meter squared (10μw/m2). Most smart meters are mounted near a bedroom wall. Their range extends to 1,400 feet. Readings that exceed 100 μw/m2 enter a range of ‘extreme concern.’ Based on the Letter of Authorization from the FCC, granted in what is called an equipment grant and which for many smart meters includes antenna gain, the present digital meters can emit up to or over 14,000 μw/m 2. That would be 140 times over the Building Biology standard! “Some smart meters use other frequencies such as 2.4 GHz, but 99% of them use 900MHz. The FCC’s ‘safety’ guideline allows 2,000 μw/m2 (2W/M2), which by our standards makes the present meters operating at 900 MHz unsafe. “The industry uses the environmental excuse that we will save the polar bears from rising oceans by saving CO², but none of this is provable as true,”Bathgate says. “Yet they are allowed to collect 10% a year as ‘Return of Investment’ on the money they spend on smart meters until the terms of return of investment get changed. The energy that digital meters need to compute and send their frequent signals adds to energy use by about 2.75 KWh’s (kilowatt hours) per day. This, multiplied by millions of meters, wipes out any benefits of using a ‘smart grid.’ And this can add up to over $120.00 per year in your individual power bill.There is no evidence that AMI meters save CO², kilowatts or money unless they ration it. Collecting data once every 15 minutes will not ever accomplish the goal of being able to match capacity to demand in real time.”
Further, he says, “There is no direct ground connection in the meter for a zero EMF reference (i.e. as a base reading). Electronic circuits in the AMI meters have multilayer circuit boards where one of those layers is a “Relative Ground” reference, which refers to ground currents or voltage that may exist on the site where the house stands. In over 1,000 house surveys I’ve done more than 50% have serious wiring errors which can contribute to an unstable Relative Ground reference and affect the accuracy of the AMI meter reading.The analog meter is not affected by this characteristic. “With the AMI meter, when a light or appliance is first turned on there is a high but extremely quick surge of power, and that level is what is recorded until the next cycle begins. For example, if you open a fridge door and you cause the compressor to turn on you will be billed at the peak consumption rate of that appliance from that moment for the next fifteen minutes, or until the next measurement. This alone can add hundreds of dollars a year to your bill.” Claims that AMI meters are more accurate than analogs are false. Says Bathgate, ”The smart meter is populated with dozens of electronic components that have tolerance swing of up to 10% which varies with temperatures and humidity. The analog meters must meet the same ANSI C12 (American National Standards Institute) specs as AMI meters, but there are no electronic components. The AMI meter does not meet the same specs as analog meters in many ways. In fact, they don’t synchronize the clocks of an electronic opt-out meter with Universal time so the calibration of measurement within certain time periods is not always accurate, and there is ‘drift.’ The analog meter has precision gears that directly convert to KWh‘s and there is no need for a clock reference. How does a device which calculates KWh‘s do that accurately if the clock drifts? “Also, light bulbs vary in power use by plus or minus 10% and LED bulbs combined with dimmer switches lead to greater inaccuracy in readings.” An exampl was testing at the University of Twente in 2016 that showed very high smart meter inaccuracies of 582% (www.utwente.nl/en/news/2017/3/313543/electronic-energymeters- false-reading s-almost-six-timeshigher- than-actual-energy-consumption) with current transformers.
“AMI meters are generally accurate to within ±10%.That is a 20% range. So, claims by utilities that the AMI is more accurate are highly suspect. This is only true in a very tightly controlled setting such as ten 100-watt incandescent bulbs in a temperature-controlled room, not with electronic appliances, motors, CFL’s, LED’s etc. (Note – a 100-watt light bulb can vary 5%).The only way to have an accurate load is with a large carbon pile which is unaffected by temperature and humidity.” Personal privacy with AMI smart meters is also a key issue for Bathgate. Your information is collected and sold to third parties, whoever they may be. And there is no security. If you’re away from home, it can be detected by hackers. Wireless networks, which use software and offer so many connection points, are easy to hack. Many in the U.S. Government, and others such as former FCC Chairman Tom Wheeler, agree and are aware that 5G wireless technology is a national security
So where it is posted overrides his qualifications? Where else could something like that be posted? FaceBook?
My experiences working with the utilities and meter manufacturers is the opposite of the article's claims.
Especially this idea that the meter can't measure surge loading in less than 15 minute increments. I'm not going to violate any non-disclosures but it's largely just a list of BS.
Does anyone think the FCC just let's them broadcast well over the accepted limits without regard for interference?
Utilities are too highly regulated to do ANYTHING without permission.
Most smart meters are mounted by a bedroom wall? Where are those statistics coming from?
Most of them are as close to the main panel in the home to lower the costs of installations, and most homes don't put the main panel in a bedroom.
And the idea that residential analog meters are more accurate, en masse, that the new smart meters is a complete joke.
This guy has an axe to grind.
My favorite factoid about most of the smart meters is how they can be turned off remotely, so if someone needs their power turned off, you don’t need to roll a truck. Very convenient if we didn’t live in the world of cyber attacks. I’m certain, however that the cyber security on these things is top-notch. No wait, the other thing…
