Prettyaimless
- Jun 17, 2021
- 9
Ok for background i have a small off grid system where i spend my summers. Its a 300 amh lifepo4 battery with 6 100 watt panels. Now the panels are all hqst 100 watt, but 2 of them are a year older than the others. And they are different. Until this point no problem they usually produce around 32 33 amps in good sun, I'm happy with that. I have them hooked up two strings of three in series and the 2 strings hooked together in parallel. Untill yesterday everything was fine but now in full sun close to midday they only produce 18 amps. I unhooked the two older panels and just ran the newer 4 and produced 23 amps so i assume something is up with the older panels. They look fine no visible damage there as clean as the other ones. These older panels are a touch over 4 years old so not old. Any ideas of the issue here? And just so you know if you're too technical its going to fly over my head speak to me like I'm ten or so haha
