SilverFox333
In your video on building your own 24v LiFePO4 battery pack out of (8) 3.3 volt cells, you state that one should not parallel more than 2 such battery packs. But in all the server rack battery systems I see, each individual 48v rack module is paralleled with the other ones in the rack. Some are paralleled with daisy-chain cables and some are paralleled with big vertical bus bars that each 48v module attaches to. So a 600Ah rack might have (6) 100Ah battery modules in it, all of them paralleled together. So - how do they do that? Over time, can one individual module have a lower internal resistance, and hence 'take over' the charging/discharging? Is module-to-module balancing sometimes necessary? If so, how best to do that?
I very much appreciate your clear explanations of so many things battery related that you have given us in your videos. Can you help me understand this one?
