muaddib721
I’ve been trying to find an answer on how exactly do you ground 6 EG4 LL V2 batteries in the rack. Do you run a ground wire from each battery to a lug attached to the rack and then ground the rack, or daisy chain the grounding lugs on each battery with the last one going to the lug on the rack, and then ground the rack? You would think the rack would be shipped with some sort of instructions. I know we have many folks in this forum using a rack of batteries so please post your grounding techniques it would be appreciated.
