For most of the flavors of LFP I'm aware of .5c is not low current.I was wondering how bad would it actually be to charge LiFePO4 batteries only at constant voltage (3.6V each cell) and low current (0.5C at most). Does anyone know how much would that decrease battery life, or if it is dangerous?
Actually when you apply a constant voltage to a cell the voltage at the interface drops to the cell voltage. People charge to 3.6 V all the time. I have grey market cells and chose to charge to 3.45 V per cell just to increase my odds. I can't quantify if any there is any life expectancy increase but I can quantify that there is not much capacity gained from 3.45 V to 3.60.was wondering how bad would it actually be to charge LiFePO4 batteries only at constant voltage (3.6V each cell) and low current (0.5C at most). Does anyone know how much would that decrease battery life, or if it is dangerous?
For most of the flavors of LFP I'm use to .5c is not low current.
In fact its the maximum that you should use.
.2c to .33c preferred.
If you only charge constant current the cells will very likely get increasingly un-balanced with ever cycle.
To clarify, what would cause that is the lack of time at Constant Voltage stage for balancing of the BMS to start or have any effect.If you only charge constant current the cells will very likely get increasingly un-balanced with ever cycle.
Until the sun goes down. If it reach full charge at breakfast time, not so good. If you reach full charge late in the afternoon, and 10 minutes later the sun goes down throwing the big universal master switch, not so bad.True constant voltage means that the supply will maintain the voltage under all load conditions. Ie it will have infinite current available
Charging at voltages higher than LFP's natural absorb voltage of about 3.4v, and holding it there until zero amps is bad. There is a tail-current value at which you stop. If you don't, you anger the little secondary-reaction gremlins which add up over time.For optimum Li life once the current tapers to close zero. The impressed voltage should be removed. Do not float Li. Even dropping to a lower voltage is bad.
I agree and I follow your recommendations. I also agree with @Goboatingnow that if someone does not follow what you are saying to the letter, then they could create a problem without knowing why.What I'm saying is that generalized sweeping statements need to be taken with a grain of salt depending on your application.
I am trying to wrap my head around real world application of this. My system is cycling all day every day with water heater elements or ac compressors kicking on and off sometimes drawing several kilowatts. It seems better to establish a float voltage than to risk near dead batteries toward sundown.Applying lab-perfect operations may make your system impractical to use in operation. Heh, there are those that treat their systems so perfectly, they get nearly no use out of them, and outlive their chemical viability.
Or at least at sundown have your batteries at full resting voltage when the sun goes down. That is better than entering darkness with only 80 percent capacity.It seems better to establish a float voltage than to risk near dead batteries toward sundown.
I don't know how that would even be possible with an off grid system like mine without running a gas generator every evening to make up whatever amps would be lacking (which would always change).Or at least at sundown have your batteries at full resting voltage when the sun goes down
No not much capacity difference, but at 3.45v, you are just slightly above the LFP's absorb "knife-edge" where given enough time (like a week or more) you will be actually full capacity if you do a discharge capacity test. At 3.6v CV, you may reach a full charge (capacity wise) in 10 minutes.People charge to 3.6 V all the time. I have grey market cells and chose to charge to 3.45 V per cell just to increase my odds. I can't quantify if any there is any life expectancy increase but I can quantify that there is not much capacity gained from 3.45 V to 3.60.
My cells are full by Noon and I charge to 3.45 V per cell. My loads are covered by solar until sundown so I enter darkness with a virtually full pack. Sometimes in winter it does not happen every day but it does not matter with Lithium. I am not off grid but my Hybrid inverter is in self consumption mode which is effectively the same. If you cannot get a full charge by afternoon during most months you do not have enough solar.I don't know how that would even be possible with an off grid system like mine without running a gas generator every evening to make up whatever amps would be lacking (which would always change).
I'm usually charged by noon as well. This time of year my energy production starts to fall off around 4pm though. I am absorbing/floating at 3.57ish for 3-4 hours a day. I do have a DIY 55ah li-ion 7s pack tied into the mix that wants to be at 4.2v, so maybe I'm not floating at all.My cells are full by Noon and I charge to 3.45 V per cell. My loads are covered by solar until sundown so I enter darkness with a virtually full pack. Sometimes in winter it does not happen every day but it does not matter with Lithium. I am not off grid but my Hybrid inverter is in self consumption mode which is effectively the same. If you cannot get a full charge by afternoon during most months you do not have enough solar.
That is the danger of jumping into the middle of a thread with out introducing oneself or making sure one is on the right thread.But yeah, if this is really about Li-Ion, well it's a whole different story.
700 ah of lifepo4 and 55 ah of li-ion all in the same system. Guess I live on the edge. lolSaw that! Was going to say there's NO wiggle room with non-lfp. Appears that you are "tieing it in" somehow? Danger Will-Robinson.
With the exception of your misunderstanding of a brief mention of the li-ion, all of my comments have been on topic. I am sure I'm on the right thread.That is the danger of jumping into the middle of a thread with out introducing oneself or making sure one is one the right thread.
I didn't intend to hijack the thread with my frankensystem. I have been mixing them for about 18 months without issue. But I also ride a motorcycle 90mph between lanes of rush hour traffic, so there's that.Yeah, sorry about that - my replies get shorter as the coffee wears off.
We'll assume you know the difference, and are very careful, using different systems for the different chemistries, but tying them together in the same charging system would just be problematic in my mind.
Looks like it's pretty well covered by the others earlier.
