kenkoh
20 feet.How far is you run from panels to scc? The efficiency is lost on a mppt from 90v to 14.4 the only advantage of high voltage is for Less voltage drop for long wire runs.
Yes.... kinda. since we are dealing with fractional volts from charged to discharged, I don't like the voltage drop across mosfett if I have an inverter/charger (It is not as big of a deal with a straight inverter). The other challenge becomes fabrication of the circuit into a reliable unit for installation. The interesting/ironic thing is that the Victron Battery Protect is essentially what you are describing, but they do not support putting the device in line with the inverter.....because of the inrush current. I could probably use the Battery protect as part of a circuit that pre-charges first but it would not be a supported configuration from Victron's perspective. (And it is an expensive solution).you can use MOSFET , no contactor, no spark, the same mostfet you use in the inverter.
and only a few miliamps to control them.
for the price of a big switch you can probably align enough MOSFET to get the necessary amps conduction
Are you sure of that? Some of the inverters talk about 'soft start' to minimize current surge, but that is on the output not the input. Every inverter I have used has the on-off switch after the capacitors. (They don't want to deal with the surge either ☹ ).
I stand corrected. The caps pre-charge as soon as the inverter is connected to power, regardless of the inverter power switch.Pretty sure. When I get a chance, I'll review it and run a few tests.
Thanks for reporting back!!!I stand corrected. The caps pre-charge as soon as the inverter is connected to power, regardless of the inverter power switch.
I keep asking myself why this has not been addressed by the inverter folks
I guess.... but I would think one of the higher quality manufacturers would see it as an opportunity to differentiate.Costs, simple as that.
The problem is the surge current through the BMS. In some cases it is enough to trip the BMS over-current protection. In any case the huge (but very short) surge is not good for the MOSFET.bms disconnect is made by MOSFET, so it is not sparking.
if you use a relay, it is another story.
I would guess this was less of a problem with lead acid batteries because of their higher internal resistance?
I predict the market is just entering its own version of the cambrian explosion and the pace of change should pick up significantly.
It looks like the "Roaring 20s" are going to start seeing the fruits of all of the battery research that has happened in the last 5-8 years and battery storage is going to go more and more mainstream. The demand for simple plug-n-play solutions will continue to grow and vendors will oblige. It will be interesting to watch how it all unfolds.
Can you provide a link to the PTC you use.I have the same design problem on my DIY disconnect, I chose the smaller resistor + PTC solution (but I'll try to find a better option).
2A >10A
+--------- fuse ---------- S<] ----------+
Vsense Vtest | |
| | 12R 50W 5% | 4.7R 50W 5% 5A >20A |
P- -----+----- disc. -----+----- res. -----+----- res. ----- fuse ----- mosfet -----+----- B-
First I drew it out..... Did I get it right?
I do not understand the MOSFET.... what is the controlling signal? Do I even have it shown in the circuit correctly?
The circuit is clearly not intended to handle the full current. Does this go where I show the resister with the rotary switch?
Could you give me a description of operation or some context of how it is used?
I was thinking something like this for a 12ohm circuit.
If the inverter is left ON while the sw is in the '1' position, the PTC would stabilize at a fairly high resistance.
Got it. Thanks.Yeah, sorry for that, this crude schematic was only for me originally, I should have made it better before posting it...
Yes, it's exactly that
The mosfet controls the precharge (it's equivalent to the position "1" of your switch). It's controlled by the BMS.
The main disconnect (equivalent to the position "2" of your switch) is between the far left (P-) and the far right (B-).
I thought you saw the thread about the BMS but apparently not, sorry: https://diysolarforum.com/threads/diy-bms-design-and-reflection.4065/ just read the part titled "The precharge and some other related features" in the second post of the thread, it should make things clearer.
Yes, it's exactly that. But be careful about the values: the resistor alone should limit the current below the PTC max current (9 A in my example) and the PTC trip current (3 A in my example) should be lower than the max current the resistor can handle continuously without getting over its power rating. Also, the PTC aren't super precise devices so you'll probably need to do real world tests to adjust the resistor and/or PTC values.
You can see all the PTC values available on Mouser here: https://www.mouser.fr/Search/Refine?N=18356427 the higher the value the lower the current (sadly the current isn't part of the parametric search and search results so you have to go to one you think is ok and look at its datasheet).
If you don't find exactly what you need you can search on another supplier or put multiple PTCs in // but they need to be the exact same ones and you need to pay attention to current sharing (i.e. don't wire one with thin long wires and the other with short big wires...) and to temperature matching (ideally you need to bond them together with a heat resistant compound).
Here is a design for a 24 volt system using a different PTC
The same PTC can be used for a 12 volt system
I have ordered a few of both PTCs and will see how well it works.
https://www.mouser.com/ProductDetail/81-PTGL06AR0R8M1B5B0 (.8 ohm, 3 amp, 16 volt)
https://www.mouser.com/ProductDetail/81-PTGLCSAS1R2K3B5A0 (1.2 ohm, 5 amp, 51Volt)
