Hello I am starting off with a very simple system right now without a solar panel. It is just a standard 12v battery and 300 watt 120v inverter.
What I want to know is how to properly ground the system. Do I connect the ground wire from the AC inverter and connect it to the negative terminal on the battery? Would it work to connect it to the ground outlet to the house? Which method is preferred? If I take it outside, how do I "ground" it if not the battery? Do I need to buy a wire attached to a metal pole and stick it in the ground?
