Connecting Battery/Inverter Negative to Inverter Ground?
Disturbedfuel15
Mich
Hello,
I'm currently running wire between a Midnite E-Panel and SMA SI-6048 (along with battery). From the following instruction, it appears I am to 'bond' (connect) the inverter/battery's negative to the entire system ground. Is this correct and necessary? I did not expect to see this but I am far from an expert. TIA.
Okay, great--that's pretty conclusive. I thought about it more like in the case of a car--the battery negative is connected to chassis ground.
I appreciate your responses!
