Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,490
When I hung my original 2.5 kW SWR-2500U inverters 17 years ago, I was probably stronger and they were only 75 lbs. I was able to carry them up a stepladder and hang them head high. Taking them down to upgrade was doable, but difficult
When I hung 75 lb transformerless 10000TLUS under the deck, those weren't too bad.
But how does a 140 pound weakling lift a 140 lb. Sunny Boy 5000US inverter?
![140 lb.jpg 140 lb.jpg](https://diysolarforum.com/data/attachments/51/51710-4d6d716b3d5baa464d619575021ffa49.jpg)
Unloading a pallet of these from my pickup (same with pallets of Sunny Island and 405 Ah 6V AGM batteries) wasn't so difficult. With a dolly and ramps, and rolling boxes off the top so I never lifted more than half the weight, it wasn't too bad. I was even able to stack the boxes two high once inside, tilting them end over end up a box staircase.
But lifting more than knee high was too much for me. Vendor recommendation was to slip a 3/4" pipe through vent holes and do a 2-man lift. My step son and I carried one that way, but lifting head high and hooking on the bracket proved too difficult.
So I once again used an engine hoist and straps, as I did for the Sunny Island. Straps through the deck boards lifted inverters below.
![hoist through deck.jpg hoist through deck.jpg](https://diysolarforum.com/data/attachments/51/51707-d512a01bae2fdc60aca0c7622b8d4efe.jpg)
For inverters on the outside wall beyond the deck, I used the pipe shown as an extension so boom reached beyond the hoist's legs. A few sandbags at the back made sure it didn't tip over.
![hoist extension.jpg hoist extension.jpg](https://diysolarforum.com/data/attachments/51/51708-ebf915c9cac4d8a3baf7dc30420e84ff.jpg)
Once at the right height, I gave it a push and lifted with my knees to get it on the bracket.
![inverter under deck.jpg inverter under deck.jpg](https://diysolarforum.com/data/attachments/51/51709-9ca9d8b8d744855716cefd9a522f4590.jpg)
