How efficient is your generator?
I've updated the original post with additional run data. The tank I just started is with the improved charging rate provided by the second inverter I installed. Yielding ~4 kW charging rate instead of closer to ~2 kW. It will be interested to see how the efficiency changes with the increased load...
Well, with an average load of (at least) 4.15 kW on this last tank the DuroMAX XP9000iH achieved around 13.9% efficiency.
I also discovered part way through this last tank an issue with how I was capturing load data metrics so the actual average load/efficiency was probably a bit higher. We'll see on the next tank, but it was good to see the efficiency go up so much with the increased load. It gives me some hope that with proper loading, propane won't be such a terrible choice from an efficiency perspective.
Code:
5 (kWh / battery) * 3/4 (battery) = 3.75 kWh capacity to charge
3.75 (kWh) / 2.5 (gal) = 1.5 kWh / gal
$6.42 (USD / gal) / 1.5 (kWh / gal) = $4.28 (USD / kWh)
1.5 (kWh generated) / 33.41 (kWh total energy) = 4.5% efficiency
@Mannfamilywoodworks I suspect something is either really wrong with your generator or maybe you're charging way slower than necessary - basically near-idling the generator while you effectively trickle-charge the battery.
How long is the generator running per charge cycle?
4 hours usually per cycle lol please help if you suspect an issue
Well, maybe not an issue per se, but probably quite a bit of opportunity to run the generator less and get more power from the same amount of fuel.
Code:
3.75 kWh / 4 h = 937.5 w average charging rate
For a 6 kW generator, it's not totally idling, however it is far below the charging rate you could have. From your other posts I think I see that you have the 48v EG4 battery which supports up to 100 A charging/discharging. So conservatively;
Code:
48 v * 100 A = 4800 watts
(Actually, the charging voltage will usually be above 50v so the charging wattage at less than 100 A could easily be in excess of 5 kW, but it's probably best for battery life to keep it in the ~4 kW range.)
TL;DR; If you added some charging equipment to charge at a rate 3 or 4 times faster you would need to run the generator about 2 to 3 hours less to get the battery full and probably only see a nominal increase in fuel consumption - i.e. much higher conversion of fuel into usable power.
Of course nothing's free so you'd need to evaluate how often you actually end up running the generator and whether it is worth it to you by comparing the value of the quiet or the cost of the extra charging equipment against the cost of the fuel & generator maintenance.
Not sure if this helps but my 18kw Kohler uses about 3 gal of LP per hour average load.
Not very much by itself. Do you have a sense for what "average load" means in average kW or total kWh for a given amount of run time?
No I’m guessing 50-60% of 18 kW. I’ll go look at the manual. I just always used 3 gal/hr for my calculations. Now that we have an AIO inverter it’s not as big an issue since the Gen now only runs to charge the batteries which for us means about 2 hrs a day on a fair solar day. Cloudy or rainy I need about 40 kWh to make it through the day so might mean 3-4 hours of gen time total.
So it a 17kW on LP 2.1 gal per hour at 50% load. So I’m looking at probably 3+ gal per hour when charging. Probably closer to 4. When charging I’m looking at 11k for the inverter and another 1.5kW for the house loads. So say 13 total when charging. So let’s say 8 gal LP per day off grid. I have 44 kWh of storage now and a 13.2 kW array. Ultimately I need another 22 kWh of storage and another 2400 watts of panel and I’m pretty well off grid.
I'm guessing the 2.1 gal/h @ 50% load is from the generator manual. Using those numbers;
Code:
17 kW * 50% = 8.5 kW
8.5 kW / 2.1 gal/h = 4.05 kWh / gal
4.05 (kWh generated) / 27.988 (kWh total energy) = 14.5% efficiency
If you have a way to measure the run time, actual propane use, and the total produced kWh, it would be interesting to see how those numbers hold up in the real world!
Code:
I lost you on the final calc. The 27.998 what is that number? What I see in real life is I usually charge at night with our low TOU rates I see around 23kWh used from the grid at this time with batteries at 100%. Now if I have an average solar day we grid sell after batteries are topped off back to 100% then start grid selling. By the end of the day I usually end up with a total grid sell for the day of 15-20kWh (that’s really 43 kWh but we used 23 to charge at night). In addition we regularly charge or buy our power for 1.5-4 cents per kWh at night and we grid sell during the day at 8-12 cents per kWh so we take advantage of that. What I would expect in a grid outage is almost the same cycle except no grid sell. We would need about 10-15 kWh from our gen to make it through the day. My Sol Ark spec says it’s 96% efficient AC to DC charging.
It's mentioned earlier in the thread, but that's the amount of chemical energy in a gallon of propane (LPG). If a theoretical propane generator were 100% efficient, you would see that many kWh produced for each gallon burned. The amount of kWh actually produced divided by that number, gives us the on-site efficiency of the generator - it obviously ignores the embodied energy of producing/transporting the fuel though.
That's pretty interesting! I assume days when you sell to the grid are also days when you don't have to run the generator at all right? Otherwise I'd imagine the generator fuel costs would wipe out any profit there pretty quick...
You'd still need to directly measure the weight or liquid volume of the propane if we wanted to determine what real-world efficiency you're getting from the generator.
So I see what you are doing. I guess it would be difficult to be accurate. I can measure the electricity end but the LP would be difficult unless I had the inclination to attach a small cylinder do a test run then weight it. 17% efficiency seems low. But it may be correct. Since our system upgrades this fall I was strictly grid tied and faced with the possibility of having to run the gen 24/7 if grid was down or at least 12 hrs a day. Since the AIO installation we can probably get by with 2-3 hrs a day. We live rural so 400 gal is what we try to keep on hand. So we are now good some 40 days instead of 8-10 days.
Yeah, no pressure ? (pun intended)
Well, I calculated 14.5% above, but either one would be better than any of the real-world propane numbers we've seen so far. (In the right ballpark though so probably possible.)
Grid backup is definitely a plus for us. And playing the TOU game increases our efficiency by probably 20%.
I drive, among other rigs, a plug in Prius, and on a Prius forum I check into from time to time, I remember one of the major geeks there reporting that, after exhaustive testing, he found that the hybrid Prius was more efficient then any small generator. Easily transportable too!
You can draw up to 1000-1200 watts off of the small 12 VDC battery, which is kept charged by the big high voltage traction battery via voltage converter, all stock Prius stuff, the gas engine coming on from time to time only when the big battery needs to be topped off. While the gas engine is on, it's running at it's optimum RPM/fuel burn/torque curve/charge rate, nothing like idling a conventional gasser to charge a battery, the Toyota engineers really did their homework and it's common for even long time Prius drivers to find new little details on how well the car works. A small 12 VDC/120AC inverter is used on the small battery, mine is 700 watts so I can charge my e bike while on the road, so the power available is limited, but REAL efficient. Some have talked about custom inverters that would work directly off the big battery, with up to 4 KW output, but that seems to be a one off thing.
I'll park mine and just leave the car ON (engine is off), while I go eat or whatever when on a road trip, knowing there is no fear of having "the battery run down," and that the amount of gas used is being burned in the most cost effective way possible. DAYS of output, on very little fuel, so the next time you hear someone diss a Prius and by extension, it's driver (!) keep that in mind. My other rigs are a 1 ton Silverado flat bed, and 60,000 pound 35 ton capacity crane truck, for when I feel the need to look macho, otherwise, at 73 years old, the darn Prius is my favorite car I've ever owned.
45 years ago, when on my first new rural property, and living out of a home made 5 th wheel trailer (it'd be called a tiny home now) I'd drive my dual battery pickup up, raise the hood, and using jumper cables power up the 12 VDC trailer circuits. Parked on a mountain, if I ever ran the batteries down enough to not start, it was a simple matter to start coasting, pop the clutch, and by the time I went into town and back the they were charged again. The yet to be invented Prius would have been a lot more convenient.
That's interesting @Ptom! I hear good things about prius' in general.
That said, without supporting numbers, I'm a little skeptical of the claim; "hybrid Prius was more efficient then any small generator."
It seems like there's probably just a lot more steps between the ICE (internal combustion engine) and 120v AC power in the Prius than in a small stand-alone generator.
Code:
ICE engine > HV DC > HV battery > voltage converter > LV DC > 120v AC inverter
ICE engine > 120v AC inverter
There's also a lot of variables which are harder to account for;
* Engine quality
* Bearing quality
* Software quality
* Wiring/winding quality
I'm not sure how best it could be measured with the Prius, but the point of this thread is "given a unit of fuel, how much electric power does it give back in kWh (and maybe how much does it cost)." Any chance you already know of numbers for the Prius in those terms or want to measure them yourself?
What a great idea. I have a mechanic friend and that’s all he drives.
Code:
* Engine quality
* Bearing quality
* Software quality
It’s sure eye opening to see the actual numbers. Much lower than expected.
Code:
Code:
I see what you’re saying now!
Currently Off the generator I have 5 outlet ports.
4-120v
1-240v
At 240v I’m maxed out at 30amps. That’s what the generator gives me.
My eg4 48v battery charger is 18amps if I remember correctly so I’m not exactly sure if I could do that with my current configuration.
Sounds nice though!
