OffGridForGood
Catch, make or grow everything you can.
I have been dealing with a pretty big storm this week, and since last year at this time we lost utility power for four days in a row, I thought I would share what we do to prepare for a winter storm in our local forcast; maybe it will help someone else, even if you live somewhere without winter storms, our approach could work for other forecasted extreme weather events, and it seems these are becoming pretty common.
The background: we run our business and our home on side by side rural properties, the off-grid set up is actually in the shop next door, with a pair of buried cables between the shop and our home. The house still has a utility connection, although we try to minimize our utility use, or we load-shift to nights when our TOU rates are half of the daytime rates. The business uses 12-14kWh per day, and the house 24kWh per day.
Earlier this week we saw in the forecast a big blow-out coming with high winds, and up to 20-inches of snow mixed with freezing rain conditions. Knowing these are the conditions that took out hundreds of trees last spring and the utility lines with them, resulting in a four day utility outage, I set up the system to charge up the batteries to 100% off-peak, and run the two properties during the day on solar/battery. It turned out the utility remained on during most of the storm, with only a four hour outage during the peak, but having the batteries all fully charged each night gave us great comfort that we were prepared. Yes, we have a back up generator and proper connections to the solar now (added Fall 2022) however the generator is effectively $1.25/kWh power supply and we try to avoid that source unless all other options are down. (note: we do run the generator about once a month for an hour to exercise it, use up any old fuel in the tank, and confirm it is available for use).
Hope this post helps others, and leads to considering the priority of fully charging batteries leading up to a forecast weather event, over minimizing utility usage.
