SimpleJack
- Apr 6, 2021
- 4
Hello, I am a newbie trying to figure out the best way to charge (for capacity tests) and top balance my cells.
I have 2 packs of 8 280Ah Eve cells and a LeTkingok EBC-A40L for charging and testing.
Would it be a problem if I were to charge a single cell for a capacity test to 3.65 volts, not use the 0.05C cut-off current of 14amps, and stop charging right when the volts hit 3.65? I cant imagine I would leave much power left to be filled. Or is it bad for the cells not to slowly ramp down charging down to the 0.05C?
Additionally, if I were to top balance 8x280Ah cells in parallel, the 0.05C rating for those cells is well above the 40amps I am putting into the pack. Could I just top balance the pack to 3.65 and have the charger stop upon hitting that 3.65 value?
