I have 10 awg SAE connectors for the portable ground solar panels outside of my RV. From the solar panels over 10 awg solar wire thru the SAE 10awg wire in to the solar DC breaker. From there on to the solar charge controller. All 10 awg. No problems. I have seen some SAE available on Amazon with 8 awg (if you want more margin). In theory the 10 awg should be good for 30amps. I have 6- 100watt flex panels (600watts) configured as portable units arranged in two groups of three wired in series parallel. Each panel Voc is 22.8 and Isc is 5.59A. In the 2S2P configuration, at best power, it should yield a max continuous current (Imp) of 10.58A and worst case Isc of 11.18A. All still well under 30A and even well below 15 amps. It will not get converted down to 12v and corresponding higher amps until it goes through the charge controller and off to the battery. So the SAE side of things is safe.
