SomebodyInGNV
- Jun 3, 2020
- 182
Hello. I'm prepping to mount my Newpowa solar panels on the roof of my Rockwood Mini-Lite. The trailer has a 1/4" lauan plywood deck, but no trusses. The only thing I have to screw into is plywood and it's not CDX roof decking but at least it's not the thin stuff used on interiors.
My panels are 58 x 26. I intend to mount them lengthwise so the leading edge in the wind will be the narrow end. There are 8 mount positions pre-drilled on each panel.
The roof has a crown which I can compensate for by using standard z-brackets on the inboard side and curved-roof brackets on the outboard side. But the curved-roof brackets are twice the price (or more) than the standard brackets. (I could make my own but don't want to go to that effort.)
Questions:
1. Are 4 brackets per 58 x 26 panel enough? If I need 6 or 8 (Newpowa recommends 2 sets for each), is there any benefit to mounting two on the leading and trailing narrow sides, or should I use 4 on each side? That would be easiest since the holes are already drilled.
2. Does being level matter? Can I just use standard Z-brackets or should I use the curved roof brackets on the outboard side? The result would be each side being canted outward slightly.
3. The fasteners that come with the brackets are self-tapping screws appropriate for mounting on metal. Should I use 1" #8 or #10 pan-head wood screws instead? Are the rubber washers on the self-tapping screws important? If so, and if I use different wood screws, do I need to add rubber washers?
Questions:
