The well pump is 240v
I would like power when the grid is down.
OK, that's a start. More details would be better. Is the pump 1/2hp, 1hp, 2hp? Pay close attention to what Hedges just mentioned. Starting surge is very large in most submersible pumps. My 240V 1hp Grunfos consumes 38A at startup, but runs at only 9.5A. My XW+6848 easily handles the startup surge. BTW, I measured the starting surge with a clamp meter that has "inrush current" capability. It's a Uni-T216C. I highly recommend it. I also have a much more expensive Fluke clamp meter. The two match each other to within 1%.
Find many great new & used options and get the best deals for UNI-T UT216C 600A Digital Clamp Meters NCV LCD Test ACDC Auto Range Multimets✦Kd at the best online prices at eBay! Free shipping for many products!
www.ebay.com
Its the surge capacity that really separates the good inverters from the junk. Look at SMA, Outback, Schneider, and Victron for serious, quality inverters. If you skip the whole-house air-conditioning, and are not pumping water all day long, I'd say you'd be very comfortable with just 10-15kWh per day, assuming you need ~10kWh for air, and 5kWh for everything else. That would be easy to obtain with a 48V system with ~3000-5000W of panels. You will need a charge controller that can handle 50-80A at 150-200V. A budget brand like an Epever 6420AN or 8415AN might work, though I myself like Midnight's 200V Classic.
Inverters might be divided up into different size classes. Look at Outback's GS4048 or Schneider's SW4048 if your power needs are not that high. Scale up to an Outback 8048 or XW-Pro 6848 to handle the bigger well-pumps, and the air-conditioners. Pay attention to those starting surges to make your decisions.
Shop for your solar panels at Craigslist. Far better deals than retail internet channels. Can you be a bit more specific in your location, Southern Florida, or Northern Alabama? We can help you find the best deals.
