sun_of_a...
Hello,
Thanks for the forum! This is regarding these: "LiTime 12V 230Ah Plus Low-Temp Protection LiFePO4 Battery, Built-In 200A BMS, Max 2944Wh Energy"
How many of these can be safely and practically put in parallel for a 12v battery bank? I've got 16 of them I was going to put in 4s4p, but thanks to the forum, I'd like to explore other scenarios now.
I'm leaning away from 4s4p because of the issue of imbalance among the cells. Does that issue just start coming back with 12v parallel in this case? Then there's a 24 volt bank to consider. I'm trying to minimize the imbalance potential now, and that's the nature of my question at this point. Thanks.
One practical issue with 12v is cable size. Note, PV would not necessarily need to go directly to this battery bank, nor would AC necessarily need to come directly from it. Maybe those are secondary issues.
The question now is how many of these can I safely and practically (wire size, buses, fuses, etc. Other?) put in parallel? And if anyone has a rough estimate of the cost of cables, fuses, buses, etc., it would be appreciated too.
