trying to install mpp solar all in one unit PIP-812LV 800W 12V in an rv....I contacted Ian, the seller, with another question and he recommended that I bridge ac input neutral to the ac output neutral. I don't know how to do this?
Thank you for your reply
Since this is just an 800 watt inverter, #14 should be sufficient... I do not like installing multiple wires under lug screws, so perhaps making a pigtail so only a single wire is under each screw, and wire nuts tie the conductors together.
I am so grateful for your responses and advice!!! I was stuck here, but your help will let me continue!! Thank you so much for taking the time to explain this to me!!
