Thank you all for your help. It is very much appreciated.
The system I envision would use a Growatt SPF3000TLLVM-24P. It only has one MPPT.
Specs
V input 2000w
Max solar charge current 80A
Max VOC 145 VDC
MPPT 30VDC-115VDC
Panels (4) 250W
VOC 37.6
VMP 30.3
8.27 Amp
This system would be located inside a camper here in Canada and due to the extreme cold in the winter it the electronics could not be stored inside over the winter. Therefor, It would have to be very portable. Hence why I'm looking at the Growatt. One device, easy in and easy out.
As for the panels. A portable series array is optimal for my needs. I do a lot of back country camping in areas with fairly dense foliage. A 2-3 panel series array, which I can locate a ways (30 ish feet) from the camper and easily (ish) relocate as needed during my stay. There is not a lot of room on the camper roof to locate panels. I think I could squeeze 2 up there. I would like them in parallel to minimize the affect of shading on them. These extra panels would help to maximize the charging potential of the system.
Option 1
single series 3 panel array : 37.6x3=112.8 @8.27A = 933.6 Watts
Option 2
Series array: 2 panels 37.6x2=75.2V @ 8.27A = 621.9W
Parallel array: 2 panels 37.6V @ 16.54 A = 621.9W
1243.8 W total
I was hoping for a device that would combine the 2 different arrays together(option 2) and then be able connect directly to the MPPT. It seems that such a device does not exist or does it?
https://solarpowercombinerbox.com/p...-with-circuit-breakers?variant=32459047206971
A 2 sting version of this combiner box with 2 20A breakers rated for 150V. Is it possible to have each string connect to a it's own 20A breaker then have this connected to the MPPT? It would make 112.8VOC and 24.81A total watts 2798.5W. Well within the parameters of the MPPT and since each string has its own 20 breaker it would not overload the combiner box either. My knowledge of this subject is quite limited but it seems feasible to me.
Thank you all again for all your help.
