That means there will still be some consumption by the BMS. AFAIK, it is small and only significant if the batteries are left unattended for a long period.NOTE: The auxiliary switch will ONLY turn off discharging, not the charging, as I just learned.
Can you explain/show how you have this wired?Isn't it weird that the solar is powering my lights (and other loads by the way) ?
If it performs as Topper's does, then yes. It should be easy to test and confirm.So when the BMS is off, the solar panels and the solar charge controller are still charging my battery.
Your MPPT and IP22 charger power the bus bars that your lights are connected to.However as I am not using the loads output of my epever charge controller, how can the lights be on ?
What is Topper ? ....
Remove the little black jumper and plug in the pigtail lead.
"Wrong", no.Do you think something is wrong with this wiring ?
Why put load stress on your MPPT when batteries do this work nearly effortlessly?
Solar charge controller (your epever MPPT) output/load.Sorry I don't know what are SCC load outputs.
Yes it needs to be fused to be safe.So you think I should add a fuse between the bus bar and the inverter ?
I would move the positive charge wires from the MPPT and IP22 to the battery side of the mega fuse. Fuse to 500w inverter (500/12.8 x 1.25 =) ~50a fuse. Fuse to 1000w inverter (1000/12.5 x 1.25=) ~100a fuse.Do you have any suggestions to improve the system
