The solar quantity is not how you decide the amount of batteries. The intended load is that.
in other words...
You need to know what you will be running off the batteries. How many watts they need, and for how long.
a simple way to find this is with a watt meter. Hook up the loads you need to run, and run them normally for a few days.
The meter will add up he watts used, and break down the watt hours consumed per day.
Then with a known need, you can add up the number of batteries you need to supply it.
if you can’t get a watt meter, you could manually add up the devices you need to run, then estimate how long each load will operate per day.
a small refrigerator pulls around 200 watts, but it only runs 3 or 4 hours a day, depending on how much the door is opened and how warm a room it is placed in.
Say 200 watts x 4 hours a day, that adds up to 800Wh per day. So for just that fridge, you need a battery with 800Wh, or at 12v, 67Ah battery.
