Ceiling fans work exceptionally well in dry california heat. It's amazing how most people go straight to thinking about getting some kind of AC unit and don't even know about evaporative cooling let alone simple ceiling fans. Our usage is so low that even using the fans all day in the summer makes a noticeable jump in usage. Which is why I don't ever imagine using AC.
Lower rhe humidity and you CAN evaporate cool here where we have "The Air You Wear"...
My air tubes lower the humidity, the ceiling fans do the rest.
By letting convection heat rise to the outside (vent) in the sun room/green house vent the home, its a no energy draw through the air tubes.
I have fans to draw the tube air into the home, but they are rarely needed.
That being said, my friend lives about 20 miles from me and sees just above a hundred for a month every summer (dry heat). He was looking into some solar powered mini splits and I suggested a swamp cooler (evaporative cooler). At 100dgs outside in the shade, 80dgs looks a lot better and it doesn't use much more energy than a large ceiling fan. He can save what little roof space he has for his grid tie panel system for all of his electronics.
My cousin just built in Phoenix area, built in a cooling tower. Water spray cools air, it falls into the home. Apparently that lowers the crap out of air conditioning bills.
He also got an ICE block cooler. Haven't got him to let me take it apart, but I understand it has small tubes that get frozen into a block of ice when energy is cheap, and they use the ice block as a heat exchanger.
Didn't research it, but a lot of links pop up when you Google it, so apparently not uncommon.
I think the climate argument makes sense for what and where to use affordable solar if at all. This thread is starting to convince me to just buy more bags of insulation for the attic (cooler / warmer). These houses didn't even come insulated and that was up to the owner who purchased new in the 60s.
I have rental homes (not really rent since they are permanent residents) and we insulated the crap out of them. It made a HUGE difference (in spite of what 'Code Guy's says).
We are all off grid, so every Watt counts...
While stacked apartments or multi-level homes have an advantage, single story has exposed walls EVERYWHERE...
A standard size, double panel window is about $150 and fall right in the hole any casement window came out of. It's ridiculously easy to change windows, which are HUGE energy dump holes.
ONE single pane window can dump as much heat as having an entire brick missing from a wall.
I bought that blow in insulation, when I bought enough to do the attic and walls, they loaned me the machine for nothing. If you have 40s-70s home that didn't require insulation before codes, this is a HUGE deal.
Just be sure to buy wall outlet gaskets before you blow that insulation in walls or you will find out how badly fitted the boxes are to the drywall or plaster!
I LEARNED about oversize face plates (25 cents each) and gaskets since I had to clean up the insulation off the floors (and everywhere else).
We aren't the 'Typical' home buyers. We find a house that's about to be demolished (highway construction, mining, mega-mall construction, etc) Run in with big steel beams & dollies, run off with the house for little or nothing.
Heavy equipment/structural moving was a family business until the 4th generation didn't have to work if they sold the company, so now they lay around and complain about the pool cleaning service or delivery people...
The steel and dollies are in my back fence row...
I won't move a concrete slab house, too flimsy, takes too much work holding it together. So imagine what happens when we have tornados...
If we find a solid built house on crawl space or basement, then we can run with it... 'construction cost', a foundation and basement.
So we have to update wiring & plumbing sometimes when it's older... MUCH easier when it's up on steel and you can get to everything!
"RECYCLE" doesn't just mean aluminum cans...
