Hi Matrico,
What inverter are you using? I am using the Schneider Electric XW Pro and I, like the others, cannot set my battery to dip switch 1 and have InsightHome find it. After I set the dip switch to 2 (or something other than 1), InsightHome finds one battery--not the 6 I have installed. I would probably cry if I was able to see 300A Maximum Discharge Current in the BMS as you have it. It seems like the XW Pro requires the "1" address, but the EG4 batteries require the "1" address in order to be considered the "main" battery. I've been fighting this for weeks. Does ANYONE know how to get the XW Pro to read all 6 batteries? If so, please... screenshots and PICTURES!
Secondly, I am still somewhat unclear what the settings should be for my Schneider Charge Controller. I have the settings below but have no idea if they are correct. I have the EG4 LLs with the 6 pin dip switches. Can anyone confirm?
Another "gotcha" I found out today is that the Schneider Electric XW Pro WILL NOT accept single phase generator power when you are running it in split phase. The only solution I've found is to buy a battery charger:
https://signaturesolar.com/eg4-chargeverter-battery-charger-48v-100a-5120w-output-240/120v-input
It blows my mind that SignatureSolar sells these hardware "systems" with absolutely no instructions on how to configure the system.
https://signaturesolar.com/complete...ll-v2-battery-powerwall-8-200-watts-of-solar/
Are these settings correct for the Schneider MPPT with EG4 LL?
