rmacgurn
does Hoymiles now offer any box to allow battery backup and self consumption modes with only residual export of unused energy (or can you cap your export in the DTU?)They do offer an API but it's a paid service that uses the S-Miles cloud, and as I understand it you get your own server to play with.
Locally, the best you can do is Sense Solar to monitor home production and consumption. It works great and for $400 it's worth it.
The Hoymiles inverter does not require a DTU to operate. It doesn't need the cloud in the way Enphase needs the cloud, but without a DTU you can't change the grid profile. It comes from the factory set for CA Rule 21. In NC, I have to change it to IEEE 1547. An installer could set it with his own DTU, then remove it.
thanks trying to decide between this system and Enphase for 30 520 watt CS panel system.
