LarryJForman
- Apr 7, 2021
- 57
Because I am going 100% electric appliances, I want to maximize the amps I can pull from shore power. I want to be able to use either 30 amp or 50 amp service. When using 50 amps, I am thinking that I might be able to use one of the 50 amp lines dedicated for the roof A/C and the other line for everything else. This means that the 50 amp service lines will be unbalanced. Will that work OK or will the 50 amp breaker trip? When using 30 amp service, I will use a modified 30 amp to 50 amp adapter with one of the 50 amp lines separated and run only to a relay. I can have a relay trip when that line has no voltage and switch the roof A/C onto the rest of the circuit breakers. The idea is that for 50 amps I don't need to be quite so careful with power usage than when I have 30 amp shore power. I hope to have 50 amp service most of the time, but be prepared if only 30 amp service is available. Any suggestions appreciated.
