ThanksOdyssey makes a couple 200+ Ah AGM batteries with 3 year warranty. They do make a bluetooth enabled AGM, but it's around 100 Ah.
Performance Series Battery Specifications | ODYSSEY® Battery
Get the specifications for ODYSSEY® marine dual purpose batteries in our Extreme Series and Performance Series categories. They deliver more power and longer service life than conventional batteries.www.odysseybattery.com
Thanks.I use SunXtender. One bank is 4x 12V 104Ah, other is 8x 6V 405 Ah.
Sun Xtender Solar Batteries - Photovoltaic Battery
The Sun Xtender Battery line consists of specialty lead-acid solar, photovoltaic batteries, and renewable energy storage batteries manufactured by Concorde Battery Corporation.sunxtender.com
I think both product lines are owned by Concord Battery.
Optimized for different purposes. Lifeline quotes cranking amps, SunXtender does not.
Home
Are you looking for a lightweight AGM battery? Concorde Battery Corporation has you covered. Visit us on our website to learn more about us. Concorde Battery Corporation manufacturers specialty agm aircraft batteries and is the leading producer of agm batteries for marine, rv, solar, aircraft...concordebattery.com
Wow! Could you please send me the EnerSys Powersafe Batteries specifications? ThanksI had a rack of 180 Ah C&D batteries that were always finicky. I still have a pair of the EnerSys Powersafe batteries that have been flawless for 8 years now.
Their website has tons of info. I had some flooded(calcium) low self discharge backup batteries. They where non-cycling/standbys. Very well made and top qaulity.Wow! Could you please send me the EnerSys Powersafe Batteries specifications? Thanks
I milked 9 years out of the 8D version of this battery. Highly recommend them
Hey Brett, I just got set of used Enersys datasafe batteries (12HX400-HR, 2 yrs old) to replace my very aged C&D batteries! This is for an Off-grid cabin, typically used <30 days per year, typically avoid going over 50% DOD. Can you share what values you use or recommend for Absorption Voltage and Float Voltage?I had a rack of 180 Ah C&D batteries that were always finicky. I still have a pair of the EnerSys Powersafe batteries that have been flawless for 8 years now.
