I am looking for the best 12v 200ah and above AGM battery.
MONBEL
Hello, Diy Solar Forum members. I am looking for the best 12v 200ah and above AGM battery that has a minimum warranty of two years. Your advice is appreciated. Thanks.
Odyssey makes a couple 200+ Ah AGM batteries with 3 year warranty. They do make a bluetooth enabled AGM, but it's around 100 Ah.
I use SunXtender. One bank is 4x 12V 104Ah, other is 8x 6V 405 Ah.
I think both product lines are owned by Concord Battery.
Optimized for different purposes. Lifeline quotes cranking amps, SunXtender does not.
Think about big yellow/red enersys powersafe
Also AGM traction/motive power batteries , sonnenschein , Trojan , industrial use batteries
A few quick links , better prices are available if you look hard
Thanks.
I had a rack of 180 Ah C&D batteries that were always finicky. I still have a pair of the EnerSys Powersafe batteries that have been flawless for 8 years now.
Wow! Could you please send me the EnerSys Powersafe Batteries specifications? Thanks
Their website has tons of info. I had some flooded(calcium) low self discharge backup batteries. They where non-cycling/standbys. Very well made and top qaulity.
Hey Brett, I just got set of used Enersys datasafe batteries (12HX400-HR, 2 yrs old) to replace my very aged C&D batteries! This is for an Off-grid cabin, typically used <30 days per year, typically avoid going over 50% DOD. Can you share what values you use or recommend for Absorption Voltage and Float Voltage?
