Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
I'll mention it here because it will not occur to anyone.
A "Survival Room" is a solution most any homeowner can implement.
- Choose a room in the home which will be a survival room. Large enough to cots / beds, the very basics like a small fridge, a microwave and a "Hot Plate" or inductive type is better.
- The electrical circuits within that room would be run to a separate sub-panel, which is in turn connected to an Inverter with batteries. * The Inverter Charger would take grid power during off-peak to charge batteries or to act as UPS if grid power fails.
- Insulate the walls with blown insulation or Rockwool or better yet foam. Same for the ceiling in that room as well as under the floor.
- An independent heating system should be installed into this room. Preferably one which does not require electricity or only low power to run a fan or so.
- An option for summer is to have some form of AC system that can service that room and be powered by the inverter system.
Survival rooms should NOT be in a basement as they can flood. Sewage backups are also a possibility as well as sewage gasses in more extreme situations. They should have at minimum one Window & Door to allow egress outside in the event of an emergency. This room must have doors to allow it to be isolated from the remainder of the house to contain the heat/cool within.
Consider that over 100 years ago, homes were built differently and more often than not, certain things were centralised / organised in homes to allow for rooms to be cutoff and to have a smaller functional space that could be maintained in the event of an emergency. Quite often the Kitchen was the center of this due to having the cooking facilities that generated heat. Look at all old houses, they were not "Open Concept" and everything could be compartmentalized and closed off as desired.
We record history and all things humanity has accomplished, they solved problems and had solutions that still work today yet many will not look back to see the creative & good solutions of day's gone past. Many of the past solutions were common-sense approaches and most often "passive" so that no external sources were needed to make use of the solutions.
