2 ways to do it.
Leave everything intact and fully charge each battery until it won’t accept anymore charge.
Look at your individual cell voltage in each battery.
If close then no worries.
If not you have to disconnect the BMS and charge each individual cell to 3.65 and 0 input amps.
If you have one cell cutting off your BMS charging( which it looks like) the other cells won’t be able to charge hence you will lose AH total.
@400bird has explained it well.
I personally have not had much luck discharging the high cells.
Had better luck charging the low cells.
