labeeman
With your panels hooked up in series, your charge controller barely has enough voltage to charge the batteries with the panels in parallel you would not be charging the batteries at all because you would not have enough voltage to charge a 24 VDC pack.4 x 200 Watt Monocrystalline Solar Panels 12V - 25-Year Power Output Warranty connected in series.
They get good sun no shade for about 5 hours. If they were connected in parallel I would get more from them.
Also there is the information I added about having AC also being available to feed the battery charging (not just solar although that is my desired configuration). I seems like I'm expecting too much from this system...
You also need to check the angle of your panels to the sun at high noon use a coke can and see how much shadow you have when set flat on the panel the longer the shadow the less power you will be making.
