Input impedance is related with the impedance of the ADC, not the shunt.A 100 mV 100 A shunt is 1 mOhm... How do you call that if not very low?
That is why I said not very high input impedance is needed.Yes but since the shunt impedance is very low you can have a low input impedance amplifier.
Looks like I am inventing electronics again when these conceps have more than half a century. This example is for allowing charging only. For discharging only just swap the behaviour of the Mosfets.Yes, please, because I really don't see how you can avoid this problem.
This device has diode emulation to allow only charge or discharge. This means body diode is not even used. Whout controlling FETs independently diode emulation cannot be performed.
As soon as current changes and body diode starts conducting, mosfet goes on to avoid conducting through the body diode. If current goes reverse, it blocks again. This is done in buck converters at hundreds kHz speed.
Yes, less than 100mA until the right polarity is detected. Is that a problem?Ok, schematic #2, there's a body diode conducting.
You were saying the opposite:
While we were trying to tell you that you can't avoid having the current going through the body diode.
Because as soon as current starts ramping up conducting through the body diode and it is detected, the mosfet goes on to avoid current conducted through the body diode. 100mA is just orientative to say as a threshold current. If current goes down and starts being reverse, the mosfet goes off blocking.Why would it be less than 100 mA? the charger will provide all the current it can...
And in the other direction? because you can't just tell the loads to limit their draw to 100 mA... (which would be useless for 99 % installations anyway given it's only a few W).
That is baked into the silicon......it is a fancy ideal diode controller.I see, you're using the shunt sensed current to control the MOSFETs. That wasn't explained on the schematic
That's a good idea
I never said that it was my design but in the case it would have been my design, it would not invalidate the concept of using emulated diode. It was not invented by me and provably not by TI (at least in the last 60 years)That is baked into the silicon......it is a fancy ideal diode controller.
Probably could have been said that this is not part of @Pidjey circuit design - but rather a function/feature of a specific device and spelled out in the datasheet.
Provably as its block diagram says there is a digital coreI've the feeling that internally those BMS chips aren't really a hardware solution but a MCU with fixed code... I can be wrong but that's the easiest solution (and by far...) so I don't see why they would do it a different way.
Yep, half of it was missing, MOSFETs alone can't do that...
Thank you for your understanding. Me too. It is something I would like to learn. I do not know if it is important/useful.I am definitely interested to learn if there is any problem with 'full rate' charging a cell from 2.5v. I do not know the answer, but very interested.
My current setup does not let any cell go below 2.9v or so and my charge setting on the Victron is on a low setting most of the time. At some point, I will need/want to fast charge from a 0% SOC battery.
I asked, low charge current is needed when battery drops to 2.5V?
I would like to avoid bat+ and bat- in the same place. Would you put shunt away or mosfets away?
Please, let me do things wrong.
If it does not work and I did not ask/listened to your recomendations, it is my problem, but please, help me moving forward writing my requieriments/features.
DISCLAIMER: I do not know if this is true, it is something I would like to learn.
I have read some people talking about that chargers not designed for lithium can damage lithium batteries. This is because after completing the charge of the batteries they do not stop charging because they are in float charging phase. I do not know if this is true.
I am curious to test the function of allowing discharging and blocking charging to overcome this problem when battery is completly charged. Charging would be blocked until next charging cycle as lithium chargers do (as I have read).
(Again, how to do it, it is my problem)
I have been 2 hours explaining you what emulation diode works when you can find it in the first link in a google search. I even prepared diagrams. You could do the same right? If I am asking it is because there are dozens of posts with contradictory information even in this forum.Hmm... before doing a BMS please read about lithium charging profile because that's like step 1 (and no, we'll not explain it in details here since it would take a lot of time and text, people already did it numerous times; again, google will answer all your questions about that).
I am do not know what it is important for other people that can be useful for me and I have not realized, that is why I am asking. Maybe you missed that learning from other people can be helpful.A list of the features you have currently would be helpful. Also, help in what way? Only you can know what you want in your BMS unless I missed something.
I asked what is the recomended C-rate for low voltage batteries and I got no answer.A bit rude... And I answered: https://diysolarforum.com/threads/i-want-to-make-my-own-bms.17003/page-7#post-198795
