The deal breaker was the morning when we fired up the Kerig coffee maker, that showed 1300 watts+ on the meter, the battery bank did sag to 22 volts but the Phoenix shut down! I realize it is only rated for 1000 watts but was hoping for a little better.
I just returned from the cabin and thought I would run our cabin off of our bunkhouse system to see if a Victron 1200 24 and 100 amp hour NIFE battery system could run our cabin for the afternoon and evening.
Well, it did surprisingly good, ran the well pump which showed 1030 watt on the power meter (Grundfos SQ) and took care of evening lighting and TV/DVD viewing. We consumed about 1250 watt hours during this trial.
The deal breaker was the morning when we fired up the Kerig coffee maker, that showed 1300 watts+ on the meter, the battery bank did sag to 22 volts but the Phoenix shut down! I realize it is only rated for 1000 watts but was hoping for a little better. The Exeltech XP1100 would of grumbled but it could do it at a clamped output.
The reason for trying this was to see if a Victron 1200 48 could be used for our cabin. I love how efficient they are, the broad voltage operating range and the VE direct option for blue tooth monitoring.
Now if they only made a true 2000 watt version of this inverter. I know they have the Mulltiplus 2000va with a built in charger but the price is more than double and I do not need a charger.
Morningstar's new Suresine is nice but they are expensive, also and I am not sure about their blue tooth ability to communicate with my TriStar MPPT 45 SCC.
How about it Victron? A 2000 watt 120 volt Phoenix with VE direct for $750?
I see you don’t have Bluetooth. I think you should get the Bluetooth
Tomthumb62 mentioned he was running his Dyson at 1800W for 90 seconds and he ended up turning it off, the 12/1200 was still going. That's using a 12V 200Ah powerurus LFP battery.If it could do 1500 watts for 3 minutes I would probably buy one and try it.
Yeah I don't know a lot about NiFe batteries but my understanding is they don't have the output amperage capabilities of a similar sized LFP battery due to the higher resistance.Good memory, Brucey! Yes, I was using a Lifepo4 battery with a 200A BMS. 1800W/12/0.91=164A. I didn't have a clamp meter on it to test actual amps, but that is the theory of it. Surge of 2400/12/0.91=219A but I don't recall the surge limit of the Powerurus 200Ah battery, but obviously it wasn't long enough to trip the BMS.
Oh don't get me wrong I wasn't dissing your system. Pretty cool tech really. I think Tom is travelling now but maybe he can benchmark his when he gets home. The Victrons have a much larger fuse than the rated continuous wattage would indicate, which makes sense if they can exceed that for quite a while.That would be correct Brucey, but its what I have to work with.
It would be nice if a load test could be performed on a 1200.
There is a YT video of a guy testing his with not the best results, barely able to do 1000 watts.
I’m home now. Perhaps soon I can make a video showing how much the 12/1200 can do. It’s not a wimp. If someone could barely do 1000W, then they had likely wiring problems, too thin, poor crimps, etc.
Eco mode on a gas generator saves fuel by reducing its output. Eco mode on a Victron inverter saves battery not by reducing output, but by going to sleep and sensing when a load is required and will wake up to deliver full power.Following as I’m in need of something that can start my 1990’s refrigerator. Running watts is ~110W, but brings my inverter gas generators to their knees if I try to start it with the generators in eco mode.
Saw that one. The hairdryer has a horrible power factor. That go power 1500W looks like a beast and has a premium pricing beyond the Victron:The YT review is done by Vlad F K . It is about a 30 minute review. He matches it up with a Go Power inverter.
Tom will your inverter hold the 1100 watt load for 3 minutes?
Thanks for doing the test.
I always watch the powerurus pricing hoping it will drop, but today saw they now have heated versions for not too much more than their regular:Good memory, Brucey! Yes, I was using a Lifepo4 battery with a 200A BMS. 1800W/12/0.91=164A. I didn't have a clamp meter on it to test actual amps, but that is the theory of it. Surge of 2400/12/0.91=219A but I don't recall the surge limit of the Powerurus 200Ah battery, but obviously it wasn't long enough to trip the BMS.
