I picked up this 40 amp MPPT from HQST.
My battery is using 18650's in a 3S60P configuration with a 60 amp BMS. While there is a LiIon setting, the manual says that it is optimized for LiFePO4. What would be the ideal settings I would use in my scenario?
Settings:
Full Voltage: 12.6V
Empty Voltage: 9V
Equalize: ??? volts
Boost: ??? volts
Float: ??? volts
How does one go about determining this information?
Thanks in advance!
Settings:
Full Voltage: 12.6V
Empty Voltage: 9V
Equalize: ??? volts
Boost: ??? volts
Float: ??? volts
Thanks in advance!
