So I say this after having hooked up well over 25 MPP Solar systems at work ... so this is not one of those bitching for no reason type things (well it actually is) ... BUT .....
The MPP Solar is an excellent system - until its not.
Until you need customer support.
Until you try to read one of their "ENGLISH" manuals.
Until you try to figure out why in 2022 they are still using Serial cables with RG45 connectors on the end (Seriously - have they never heard of a USB connector!!) ...
There's just toooo many lighter, better, faster, cheaper systems coming on board to go thru this MPP headache any longer ... Sure back in the day when MPP Solar was really the only "slightly better than the rest" I would defend them and basically say that there wasn't really a choice out there that we could all afford .. but there is NOW -- and several of them ...
Manuals are mostly wrong - you waste several hours trying to figure out what they actually mean
OMG their WiFi software WATCHPOWER is sooo bad its not even funny - you can't even see anything you need... and everything comes out in PDF format instead of Excel...
There customer support is random at best -- and typically they are answering a question that you are not asking.... Their first answer is always - have you read the manual -- if you say Yes then they say - well tell us exactly what the issue is (which we already had) .. then they send you a response involving UNICORNs and Candy but not a solution...
AGAIN - Who the hell is using a serial to RG45 cable in the last decade ?? -- did they find a huge supply from 1990 they have to use up ... ??? ZERO of our laptops out here have an RG45 connector to plug into ...
My list actually goes on and on .. but all I can say is - before you start drinking the MPP Solar Kool-Aid you might want to look around at other alternatives ... For me personally - I'm done -- your playing Russian roulette hoping that if/when your system has any issues - that someone on YOUTUBE has made a solution because I promise you support is zero ...
Again - everyone of my MPP solar's are still up and running -- BUT it has been an "ass-pain" to get some of them to do what they say they can do.
aaaaggghhhhhhh
I sympathize with you.
I have been RVing fulltime for over 30 years and finally decided to go solar. Not being " electrically/ solar" minded, I researched a lot on forums, read the DIY SOLAR books, consulted with other solar experienced RVers.
Decided to go to solarkits.com and order everything...MPPTsolar 6048 hybrid Inverter, 6 x200w panels and 4x LifePO4 200ah batteries.
Also decided to build a tow behind "solar trailer" with all equipment self contained. The trailer has a 50 amp shore power plug on the rear into which I plug the RV.
Hooked it all up and ran great!
At one time, I had a Dehydrator running for 20 hours, making jerky and the fridge, microwave for 6 minutes and a few lights. Great!
Shut down for a few days after this initial test and batteries voltage was 49.8.
Then, switched on again with only fridge running while we went hiking for about 5 hour's hours ...
When we returned, the inverter was off and emitting a continuous beep. I could only stop this by disconnecting the batteries!
Checked battery voltage. The 2 middle batteries in the series were 0.1volts! The other two were 11.9.
Tried charging the bad batteries (SOK) with a regular charger but still 0.1v.
Ordered a lithium ion charger and raised the two bad batteries to 12.9v.
So reconnected the four batteries in series, hooked up the panels and NOTHING! Inverter would not switch on. Measured the output voltage from the four batteries and only 23.4volts! So obviously the inbuilt BMS in the two bad batteries are bad. But the inverter as well?
The Inverter should switch on automatically when panels are connected and sun is out. But no sign of life...
What gives?
