travisandblair
- Jun 3, 2022
- 11
So Ian from MPP got back to me and had me adjust some of my settings. Before this, I thought that since I wasn't hooked up to the grid or any utility input, those settings wouldn't matter. Ian had me tweak some things, but specifically had me adjust option 21 (battery stop charging while utility is available) down from 58 (default on my unit) to 49. He said that if it is set too high, it will be locked into utility charging until the battery voltage gets up to 57v. My ignorance figured that if utility power wasn't available this setting wouldn't affect anything. I was wrong. Right after I fixed this, my system started behaving normally and my battery went up to 99% SOC (on it's display). He also had me switch option 10 (charger source priority) from solar only to solar and utility (even though I don't have utility).The LVX 6048 I have will not show the available PV wattage only what it is actually using. Once I put it into Grid feedback I get a good idea what the panels are doing in semi real time.
Your battery charging parameters are needed to understand what you have going on.
It seems like I missed the nuances of the MPP settings because I thought they would just make sense. I am very pleased with Ian's knowledge though and his customer support. Hopefully my systems stays working and it wasn't just a fluke.
