Adam De Lay
Solar Wizard
Yeah, this option doesn't have anything specifically to do with charging. When your voltage (or SOC if you have battery communication set up) drops below this level, your inverter will switch all your loads over to AC IN to power your loads. Then once the value for option 13 is hit, it will switch back to batteries to be supplying your load.12) This is the first "unknown" setting I am hitting. One evening with tech support we set this up to 51v, which is the max, and the system charged for about 4 hours, quit and hasn't charged again. Another tech said raising this number shouldn't have anything to do with charging.
I do wonder though if the reason your batteries charged for 4 hours was due to that "gotcha" I mentioned. You were in a "utility" mode for 4 hours and your system allowed charging from solar and AC IN.
Here's 2 things I would try.
1. Throw the solar disconnect switch to ensure that no PV is coming in at all (if the inverters detect any, it won't charge from AC IN). Then fire up your generator and see if charging begins.
2. Switch option 1 to USB and then fire up the generator and see if charging begins. Be aware in this mode, the generator will also be running the loads while charging the batteries.
