Hi Folks,
While building rv 12v pack in 4S2P LIFEPo4 cells 280ah (8 cells) I found that a best access physical location to place system wide kill switch would be right off the main POS first cell. Typical diagrams shows the switch located near main bus bar, after the main fuse and, in my case, a main contractor. Would it be acceptable to have it from the Cell+ post? I am also adding another one to the bus bar as well. I am just concern if the switch from the battery side can cause resistance for Contractor or REC BMS, that I will be using. If that is not advisable what other options do I have without moving it to the busbar? Thanks a lot in advance.
