What's the difference here? I'm not buying magic marketing "shade proof"
For $339 those are crazy expensive 100 watt panels. You can get brand new 480 watt panels for that money.
Yea, pure marketing as usual. The price is ludicrous, no doubt about it but there's few things that panel has going for itself. Probably the only HV 100W half-cut panel design. The price will probably go down imo, sooner than later.
Though, for a moment, what I've found very interesting was the HV panel's Voc, Vmp, and Isc.
Specifically,
If that panel was designed to be connected in series as well(
Which it is not!), starting as small as within a 3x3ft/1x1Meter footprint where you could have a 48V compatible array. And on top of that, a lot of potential for all sorts of array configurations for smaller, perhaps portable systems.
Again, the panel can not be connected in series with another panel so there's that.
However, this panel can still serve the purpose for smaller 12V/24V systems by having multiple in parallel. But think there was a mention that there's a limit to how many in parallel as well.
With all this being said, it gets me thinking,
If someone would produce such HV 100W half-cut panel that could be connected in series as well as in parallel, with a lower Voc of say 42V ish and a tad bit higher Isc respectively so it fits the specs of many SCCs on the market, and priced it appropriately, I believe such panel would be the top seller one.
Would introduce an unprecedented amount of options to customers with smaller solar power systems, yet easily upscaled to more serious solar power figures. Almost revolutionary so to speak.
Anyhow, If some manufacturer comes across this thread, do it!
