So a basic VOC and amps at standard temperature (77*F?) with the math for the event marshal(s) should verify their rating criteria the day of the event.
A single or several manufactured panels would have the same testing criteria so that should not be a problem.
A vom would verify your printouts. Hard tires with as minimal as possible contact patch and perhaps a 10W oil or mineral oil (test it?) in the bearings instead of grease and there are two huge things - if kept top secret- that will give you an advantage.
I’d like to see the joyous report when you win
