compost
Novice,
2000 watt Renogy makes an attempt, shuts down quickly.
Contacted Renogy said" not enough power to run the unit.
I had it on one 12 volt lithium 100amp dr Prep battery.
Voltage on the battery is 13.4 also same reading 13.4.
Purchased two additional batteries, parallel.
Purchased 1000 watt inverter, Renogy.
Same result...inverter slightly starts, beeps, and shuts down.
I would appreciate any directions with this situation. The unit is in a garage, mounted on a board without any load. Three 100 watt solar panels, series.
