vincentdsnt
- Apr 4, 2021
- 6
I am building the same12 volt 280AH Milk Crate battery using the exact cells and MPP Solar charger / Inverter, the difference is I am using a different BMS ( from Overkill Solar 120A ). I am not sure about using 12 volts from the cells ? Do I just draw voltage from the 12volt fuse box or do I need to install a Buck / Boost converter before the 12v fused panel so I get a true 12volts to the USB and 12volt power points I plan to wire into the the system ?
