Class T and MRBF are two that are often used for main battery protection and/or inverter circuits. These also tend to be the two types I've seen recommended by inverter manufacturers.
Edit: Personally I wouldn't bother with any shenanigans with the cheap breakers, I understand your desire here, but its the wrong place to pinch pennies I think. Particularly because even with the cheap/knockoff 250A breaker, you are still 50A shy of the inverter manufacturer recommendation of 300A.
If you properly size your main battery fuse, there is little chance of it ever blowing unless there is a big problem, in which case reset vs replace is the least of your worries.
