Guy from Glasgow
People say here that it is completely OK to have panels/string max power current quit a bit greater than mppts max current. They say Mppt will only take what it can handle.
I.e. mppt will limit current from the panels on this situation and everything will be fine. Correct?
Similar situation arises when one of the panels in a string is shaded and limits current in the string. The shaded panel limits current of the string.
Should I conclude that this full shade on one panel is completely harmless to both shaded panel and the rest sunny panels?
Or is shaded panel going to overheat and will die prematurely because of that? In a couple of years for example?
I think it is supposed to be bad for individual cells to be shaded and overheated as a result. Hence the question.
Ta!
Ta!
