Hi all!
Im a bit confused about one thing about the inverter max PV input that says 9000wp
I really cant figure out how do you get to this 9000w?? Every configuration i make is overvoltage or over current!
For example the inverter has 2x 12.5amp inputs and a max of 600v and max i got was like 5500w by choosing panels that fit the bill.
Than it made me question if lets say you set a 15 amp array to the inverters 12.5 input would the inverter simply just use 12.5 and thats it?
As far as i understand current is not pushed but drawn so the inverter will use the max available? Correct?
P.s. its a huawei inverter
Thanks and sorry if its a dum question
