I am in Kansas so we get a fair bit of sun in the summer. I have awning over my patio that gets full sun all day and it would be perfect to add some solar panels on top, the area is roughly 22' x 12'. My thoughts are this I can fit 9 panels in a 3x3 grid, was looking at the Canadian Solar 400W Bifacial Solar Panel (Silver)| Up to 520W with Bifacial Gain | CS3W-400PB-AG. So in a perfect world that is 4680w and I want to feed that into a Growatt 6kW Grid-Tie Inverter | MIN 6000TL-X. All in I am looking at around $3000 plus wires and connectors.
I would just wire all the panels in series and then run that to the inverter and tie it into my main panel. I would use a licensed electrician to make the connection to the panel and to the grid but otherwise I could do the rest myself. I don't expect this system totally offset my usage but I hope I am correctly assuming it would make a good bit of power and lower my bill a good bit. The plan is for the panels to be totally flat on the patio roof and there is zero obstruction.
So my question is am I correctly understanding what the Growatt unit does and am I missing anything big in the setup, also any idea of expected actual power generation.
